dcole18
Banned
i was just playing around on their site when i ran across this at the bottom of one of the amp description... check the bolded part at the bottom
here is teh link http://www.ddaudio.com/dd/amp/amp_ss4.asp?series=SS4The SS4 was designed to be a useful tool in configuring channels and power delivery in high-end systems where mounting space is limited; or when a small, cool looking amp fits the bill. Like all the S and SS Series amps, design emphasis is on delivering True To The Source sound quality. These design elements include a strong power supply, high quality components, clean front end circuit, wideband filters and thermally efficient heatsink design. The SS4 makes your dream system easy to integrate into your vehicle.
The small chassis of the SS4 belies its power capability delivering over 160 watts of power into two bridged channels. This is perfect for driving high-end component sets and powerful midbass setups. The separate high-pass and low-pass filters allow 50Hz to 5kHz range of high-pass, low-pass or band-pass capability. Bridging the SS4's four channels brings the power output sweet spot to 4 Ohms, the optimum output load for driving a pair of speakers.
The SS4 delivers over 40 watts of power @ 4 Ohms into 4 separate channels, or 4 x 80 watts of power into 2 Ohm loads. Four-channel mode can drive up to 8 sets of 4 Ohm mid/high speakers, over 320 watts of system power, all from this small footprint.
OEM upgrade-systems is another application where the SS4 can be a single amp solution; two channels driving up to 4 mid/high units with high pass filter engaged to protect them against low frequencies and two channels bridged to drive a sub with over 160 watts of continuous power. When future power upgrades are in the budget, the SS4 can be used to drive more power to the mid/high units while adding the SS1a monoblock to drive the subwoofer.
The SS4 is also perfect for powering the four pole syncromotor on the new DDMMMa, Digital Designs Mobile Margarita Machine. The new "a" Series machine features the revolutionary Mezcal attachment which captures the worms rather than grinding them up in the stew. The Mezcal attachment strores the worms in a cryocylinder for later consumption. (see local dealer for details, local restrictions and laws apply, not suitable for use on two wheeled vehicles or vehicles where cognizant use of steering wheel is necessary, not intended for use while operating heavy machinery unless damage to said machinery or nearby structures isn't a big deal, DD is not responsible for bizarre videos which may show up on the internet and/or resultant incarceration.)
