Sold DD S4a
Loudman
1. Product:
Thread for a ddS4a, one of the cleanest amp I have heard. I have one already so no need for this one. Its absolutely brand new in the box. Only powered up to test to see if it works and it does.
2. Specs:
Here are the specs
SPECIFICATIONS
Series S
Input Sensitivity 0.2V - 8V
Variable High Pass Filter 20 Hz - 500 Hz (200 - 5 kHz) at 24dB/Oct
Variable Low Pass Filter 50 Hz - 500 Hz (500 - 5 kHz) at 24dB/Oct
Clipping Display LED
Tested Voltage 14.4
Tested THD 1%
Model S4a
Cont Power at 4 ohm 100W x 2ch + 200W x 2ch
Cont Power at 2 ohm 150W x 2ch + 300W x 2ch
Damping Factor >550 @ 2 ohm
Cont Power at 1 ohm
Cont Power at 4 ohm Mono
300W x 1ch + 600W x 1ch
Dynamic Power 400W x 1ch + 800W x 1ch
Efficiency thru Output >64%
Dimensions - mm 420L x 232W x 63.5H
Dimensions - inches 16.54L x 9.13W x 2.5H
Signal to Noise 95 dB
Shipping Weight
3. Description/Condition:
Absolutely brand new, no scratches, no dents, no blemishes, no fingerprints!!! (lol)
4. Price: :
$425 obo and absolutely no TRADES!!!
5. Pictures:
im interested in the amp.. question is though is it the older original model or the upgraded model thats rated @ 12 volts?FYI to you idiots this amp is comparable to the like of arc audio mid line and zapco midline amps..
if its rated @ 1%thd doesn't mean its a high level.. an actually 1% THD is the threshold of audible distortion. IE when you reach a full 1% you can hear it..
whats more important is the slew rate ,damping factor, stereo separation and s/n ratio as well as the preamp section thats superior to alot of the 4 channel amps on the market.. if its rated @ 1%thd @ 12 volts its going to easily put out 125x2 and 175x2 @ 13.8 with less than audible THD...
This is definitely the newest model that DD has.
Loudman
Loudman
Maryland
ithertz
