Sold DD/RE Hybrid, Zapco, Clarion
frkkevin
Pictures
Clarion 4/3/2 APA4162 - http://www.putfile.com/frkkevin/images/83415
Zapco Amps - http://www.putfile.com/frkkevin/images/84589
RE/DD - http://www.putfile.com/frkkevin/images/84771
$180+ shipping obo
RE SX 15" (DD Soft parts)
DVC 1ohm
Whoever did the recone left the tinsels too long. I can shorten them or you can.. It did wear a small hole in the spider but not bad enough to worry.
$75 shipped
Maximum Power Output 260w (65wx4)
Continous Average Power Output 160w (40x4 into 4ohms 20Hz-20kHz @ 0.08% THD
Typical 2-ohm Stereo 65wx4 @ 0.8% THD
Typical Bridged Power 120wx2 @ 0.8% THD
Bass Exterender Control 0-12dB
Adjustable 4-channel 50hz-200hz, 12dB/oct. High/Low Pass Crossover
Mixed-Mode Operation
Bridgable 4-, 3, or 2-Channel Operation
Pulse-Width Regulated MOSFET Power Supply
Both Zapco Amps: $275 shipped
If you want one I'd like to have a buyer for the second before they are split. I bought these to run an active setup so if I don't sell both I'd rather keep them and follow through with my plans in my next car.
Zapco MODEL Z100S2
2 x 50w rms
Specs:
Power/Mode
130 watts @ 4 ohm Stereo .02% THD
190 watts @ 2 ohm Stereo .04% THD
190 watts @ 4 ohm Mono .04% THD
Frequency Response 20-20kHz
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 40 V/uS
Damping Factor 300 @ 4 ohms
Input Sensitivity .25-2.5 volts
Power Requirements 22amps, max, @ 2 ohm
Fuse Internal, 30A
Minimum Load 2ohms Nominal Stereo, 4 ohms nominal mono
Idle Current .8A
Dimensions 10.25"x6"x2.25"
Zapco MODEL Z150S2
2 x 75w rms
Specs:
160 watts @ 4 ohm Stereo .02% THD
250 watts @ 2 ohm Stereo .005% THD
250 watts @ 4 ohm Mono .04% THD
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 50 V/uS
Fuse Internal, 20A
Idle Current .85A
Dimensions 11.625"x6"x2.25"
forum moves too fast.. needs more specific for sale sections //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif lol
frkkevin
frkkevin
US
frkkevin
