DD M2a 1600wrms @11.9v
fatisbac
Digital Designs M2a monoblock amp
Input Sensitivity 0.2V - 8V Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct Variable Sub-sonic Filter 10Hz - 50Hz @ 24dB/Oct Tested Voltage 11.9 VDC signal to Noise >100dB Cont power at 1 ohm 1600W x 1ch Bridged
Dynamic power 3000w Efficiency thru Output
Dimensions - mm 400L x 232W x 63.5H Dimensions - inches 15.75L x 9.13W x 2.5L Shipping Weight 15 lbs
$450 Shipped Conus. International I will have to get you a shipping quote. This is shipping from Gainesville GA so if you are local to the Atlanta area I can work out a better price for pickup.
This amp is a beast. If you know DD then you know what this can do. I was running a DD 9515 at .5ohm on this and it never once over heated or went into protection. I have the box and bass nob that shipped with it. Bass nob has power and clipping light on it. This amp is very stable at .5ohm with the right electrical. You can burp this at .25ohm. I never took it below .5, and I was running it off a 200 amp alt and a HC2400amp battery.
View attachment 26541561View attachment 26541560View attachment 26541559View attachment 26541562View attachment 26541563
na, I only ran the set up for about 4-6 months as my daily, then I got a 350z so I cant use it anymore. I did meter a 155 in my truck though. I know on average these things will do around 2500 rms at .5ohm
fatisbac
fatisbac
Gainesville, GA
av83
