DD M.80 or eD NINe.1?
joeybutts
VA
I have both in my possession but need to get rid of one. Whichever I go with will be in my Std Cab Ranger and will never power a sub needing more than 1000W. The M.80 is about 800W @ 1 ohm (supposedly can put down a bit more than that) while the NINe.1 easily does 1400W @ 1ohm (truck hasn't dipped below 13.8V).
I just can't make up my mind. The ONLY reason I can see to keep the M.80 over the NINe.1 is that the M.80 is significantly smaller. Right now I'm powering an eD 13Av.2 in a 2.3 cu ft ported enclosure and the vehicle is much more SQ oriented than SPL.
Please don't hesitate to lend your thoughts. Whatever I choose to not use will be sold!
Definitely! I love the 9.1, I just know how limited on space it is in there, just not sure if there is any benefit to me using it. I know headroom is a blessing, but think I am at a good spot with the m.80 unless someone can educate me wiser. And the M.80 would be so much easier to implement.
Thanks bump!
I just cannot see going with the dd when u have such a good alternative in your possession. The dd will do well however and if that's all. U can fit so be it.
If you do use the dd what do u plan on doing with the Ed??$?
keep the ed its a monster of an amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif no gain by using the dd
if you really want to go smaller and more effecient get a mmats amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
guy on floridaspl is elling his mmats 1100.1 for 200 bucks
Hahahha. Man, you guys are persuasive. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I'll see about fitting the eD in there along with the two XXD 4080's that will be in there and the 13A ported that is already in there. :p I'll keep you posted on what happens!
joeybutts
joeybutts
VA
joeybutts
