Dca1600
Does anyone own one?
i heard they are a little under rated?
and i would buy a used orion for 400 but i have stock electrical and someone told me this would be fine on my stock electrical if i have good wiring
COMPETITION MONO BLOCK POWER AMPLIFIER
4 ohm RMS Power: 1 x 50 Watts
2 ohm RMS Power: 1 x 1000 Watts
1 Ohm RMS Power: 1 x 1600 Watts
2 Amps Bridged: 1 x 3200 Watts
Frequency Response: 10Hz - 500Hz
S/N Ratio: >100 db
Damping Factor: >500 @ 100Hz
Minimum THD:
Low Pass Crossover: 35Hz - 250Hz
Subsonic High Pass Filter: 10Hz - 50Hz
Bass Boost Equalization: 0-18db @ 45Hz
Lucite Encapsulated Large 2 and 4 Gauge Connection Terminals
Dash Board Bass Remote
Input Voltage: 200 mV - 6 Volts
Dual-Amp Bridging for Double the Power @ 2 Ohms
Master/Slave Control
Adjustable Phase Control
RCA Line-In/Line-Out Jacks
24db Crossover Roll Off
Dimensions: 13" x 9.5" x 3.5"
MSRP $839.00
its gona be powering a DD 3515 DVC 2
the three big wirings are? i know the one from the battery to the amp and what else //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
go to the wiring and electrical section and there is a sticky in there that explains what it is. it's the wiring between your battery and alternator. personally, for 1600 watts, i would go with o/1 guage from the batt. to the amp, especially when you find out that the sub is gonna drown out your stock speakers. you might want to ugrade later and put some speakers in your doors that will keep up, which will need a second amp.
oh i def know all that base will drown out my speakers =]
i will prob upgrade later on.
Alright, hmm i need something that has everything like a wiring kit,
do you know any online for say around 50 bucks to fit my criteria
Magnatus
Banned
Magnatus
AZ
Magnatus
