dc1.2 specs
mylows10
B2,singer,ampere rep
ok i have had a couple of you guys ask about the new dc 1.2 amps ,so here are the specs
Items Features Voltage 1.2k
Output Power (RMS) at 4 ohm 14.4V 350W x 1
at 2 ohm 700W x 1
at 1 ohm 1200W x 1
at 1 ohm 16V 1450W x 1
at 1 ohm 18V na
Working Voltage 9V~16V
Power Transformers 2pcs
Frequency Response Hz (-3dB) Hz 20~250
Signal to Noise Ratio dB 95
Damping factor 100
Efficiency @ 4ohm % 81%
Low Level Input V 6V - 0.2mV
Line Output Yes
Low Pass Filter Switchable
( @ 24 dB Slope) Variable Hz 35~250
Bass Boost @45Hz Switchable
Variable dB 0 ~ 9
Subsonic Filter Switchable
( @ 24dB slope ) Variable Hz 10~50
Phase Shift Switchable na
Variable degree 0 ~ 180
Master/slave Yes
Remote Level Control Yes
Double Sided PCB 1 oz Yes
2 oz
3 oz
Indicator Power Yes
Protection Yes
Clip No
Speaker & Power terminal Mold Type 4Ga
Power Gauge Yes
Fuses Built-in
External
Heatsink Finish Black Anodyze Yes
Heatsink Length inch/mm 11.81"/300mm
Heatsink Width inch/mm 9.38"/238mm
Heatsink Height inch/mm 2.35"/59.6mm
mylows10
mylows10
monterey , ca
mylows10
