Db Meter???
Could calibrate it with really fancy test gear measuring air pressure in kilopascals, and convert that number to decibels...probably set at an average value depending on elevation.
I don't know, I'm just thinking out loud.
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif does that mean you basically agree with my statement? //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
if i were to think out loud it would scare people
It's not that TL's are "accurate" per se, but they are the most CONSISTENT.
While they may not be consistent from meter to meter, one meter will most likely do the same score over and over again in the same car/volume/setup/etc. I've seen audiocontrols range anywhere from 5-15 dB different while the most i've seen termlabs differ is about 2 dB.
I can do a 151.0 on monday, then do a 151.0 again on friday. All the audiocontrols I've been on have been ALL over the place. Sometimes the same meter will read 5 dB higher than it did on my first run. Plus, if you don't calibrate them often they can be really wacked out.
I was lookin at walmart the other day and i seen a db meter... u plug it in the cigrette lighter and it gives u a digital display of what deebee's ur hittin... i wonder how accurate soemthing like this would be?
You seen this at walmart? The only one I have ever seen at walmart is that schoshe boom stick thingy.
pitbull12888
waxhaw,NC
pitbull12888
