dB and loudness of sounds from distances
Daints
21
MN
I know that dB double in loudness every 3 but i remember seeing someone explain how loud something is at a certain distance, i understand its not linear, its logrithmic but can someone explain the whole equation for decibels at distances
Good websites to look at:
Sound Pressure Level
Sound Power Level
Decibel
Acoustics
Amplitude
Loudness
These are all Wikis, and therefore are not 100% verified accurate, but are for the most part true.
Ah finally found this... you'll like
The Psychoacoustic Loudness
Notice: Psycho acousticians tell us, that a 10 dB increase of level
give the impression of the doubling the loudness (volume).
Your loudspeakers need 10 times more power.
If you have 6 violins as source, then you have to ten times the violins;
you need 60 violins to double the psycho-acoustic loudness (volume).
Half loudness ≡ level: –10 dB Double loudness ≡ level: +10 dB
Half sound pressure ≡ level: –6 dB Double sound pressure ≡ level: +6 dB
Half power ≡ level: –3 dB Double power: ≡ level +3 dB
four times power ≡ level: +6 dB Ten times power ≡ level: +10 dB
Double distance ≡ level: –6 dB Double sources (Double power) ≡ +3 dB
Source
Subjectively perceived loudness (volume),
objectively measured sound pressure (voltage), and
theoretically calculated sound intensity (acoustic power)
Level
Change Volume
Loudness Voltage
Sound pressure Acoustic Power
Sound Intensity
+40 dB 16 100 10000
+30 dB 8 31.6 1000
+20 dB 4 10 100
+10 dB 2.0 = double 3.16 = √10 10
+6 dB 1.52 times 2.0 = double 4.0
+3 dB 1.23 times 1.414 times = √2 2.0 = double
- - - - ±0 dB - - - - - - - - 1.0 - - - - - - - - - - - 1.0 - - - - - - - - - - - - 1.0 - - - - -
−3 dB 0.816 times 0.707 times 0.5 = half
−6 dB 0.660 times 0.5 = half 0.25
−10 dB 0.5 = half 0.316 0.1
−20 dB 0.25 0.100 0.01
−30 dB 0.125 0.0316 0.001
−40 dB 0.0625 0.0100 0.0001
Log. quantity Psycho quantity Field quantity Energy quantity
dB change Loudness multipl. Amplitude multiplier Power multiplier
Daints
Daints
MN
outsideshot23
