Dash kit doesn't fit/Only one Subwoofer output? Help please
gijeff23
I'm trying to install a Pyle PLDN74BTI 7" LCD DVD Player in my 2007
Explorer, and I have two problems:
1) The dash kit for my '07 Explorer isn't fitting around the DVD Player.
The DVD player is too large - the motorized face, when in the
upright/closed position, won't fit inside of it. It'd be quite a bit to
shave off.. any suggestions on how to make this work?
2) My RCA cable from my amp for my subs has a L & an R cable... the
output from my DVD Player only has one RCA SW Out. How am I supposed to
connect these?
Thank you for the help.
Jeff
It's just a double din 7" LCD dvd player - I wouldn't think there is anything different about its size than others. Is this not a typical problem for double din dvd players?
Ace is right bout the y splutter for the RCA. 1 male -
If the DVD players to big for the hole youll have to find someone to do some expensive fiberglass work.
Otherwise you have the wrong kit.
gijeff23
gijeff23
Evansville, IN
15bass
