damping factor?
http://en.wikipedia.org/wiki/Damping_factor
Some argue that DF as low as 10 is good enough to drive a speaker well.
In the Wiki, there is a note that Nelson Pass and others claim there is
a way to drive speakers with DF = 0.
Marketing literature tells you that you need DF = a million to drive a speaker
well. lol
Since most good amps already gave a DF of a few hundred, then it's safe to say
those amps have more than enough to do the job.
Sometimes high DF is a byproduct of an over engineered design.
*bump*
To quote Robert Zeff:
Anything over 50 is gravy. I'd like to take this time to dispel another myth, that super high damping factors make an audible improvement. A damping factor of 50 means that the amplifier's actual output impedance divided into the load impedance is 50. In this example (he was testing a Diamond Audio D7 amplifier for Car Audio Magazine) the amplifier's internal impedance is .08 ohms. A typical four ohm speaker typically has 3.2 ohms of internal DC resistance. So, the actual damping factor could not be better than 4/3.2 = 1.25! That is why emphasis on ultra high damping means nothing sonically.
saltyreefguy
saltyreefguy
palmdale, ca
JimJ
