daisy chaining 2-2500D's prob...
SPL140.2
Team DefJ
Does anyone know how to correctly do this??? 2-Orion 2500D amps. Ive tried following the directions in the manual but it will not work //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I set 1 amp to master set it to 50VAC put a rca cable on the output to the other amps preout in set all gains and eqs, bass boost... off and down all the way and moved the switch to copy. Im not getting nothing out of the slave amp. So I tried the other amp did same thing above to it and nothing out of it. What am I doing wrong???
egg
I dont think you can do that with 2500D's without a bridging module. Unless the new ones can and I am behind the times.....
x2 ^^^. Ive heard that they are pretty pricey. Thats if you can even find them, but that is all here say. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
2500D's dont have a slave/master switch on em....do they? if they do i never noticed one on mine. good thing you got the rca splitters //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif they dont like to be daisy chained at all, ive heard of voltage spikes through the rca's and frying one of the 2500D's when they're daisy chained...so how many VAC's are you getting through each of them??
I maxed out on gaining spl at 51VAC wired .75ohms to each amp, Its really hard to get an exact Vac on both amps though + - like .2 or .3 that VAC was at 53hz. Holy voltage dropp when rev the engine to 2k rpm drops to 1.5Krpm thats with extra batt and 200 amp alty.
egg
thats pretty much close, not satisfied?
Nope Im not //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif test enclosure #1 sucked maxed out with 146.67db at dash car sealed up. Im pretty sure the 2 4" aeros were not big enough for the enclosure but thats all I had room for. Started test enclosure #2 today sub,sub,port. Slot port will have 94.5 area, cant wait till its done to get this tested.
egg
SPL140.2
Team DefJ
SPL140.2
NY
SPL140.2
