Hi,
I want to improve the audio in my Dacia Logan 3 and I’m looking for a plug&play amplifier. Right now I’m considering two options: Phoenix Gold ZDA4.8 and PUZU PZ-D8. I picked these because they are relatively cheap and should work with my factory head unit, which has a speaker detection/protection circuit. The ZDA4.8 has speaker load simulation according to the specs, and the cheaper PUZU PZ-C7 is known to work with similar head units, so I assume the PZ-D8 will too (the seller also confirmed it).
- PUZU PZ-D8: Chinese brand can be a good product in its price range, or it can be junk. You could say it's Schrodinger's DSP: it's both good and bad at the same time... anyway lower price (~$350), higher rated power (4×80W RMS), smaller size, probably less heat. However, apart from the 2 Infineon MA5332MS chips, the other components are unknown, and the real output power might be overstated (just like in the PZ-C7).
- Phoenix Gold ZDA4.8: well-known brand, available locally with 2-year warranty and 30-day return, but more expensive (~$440) and rated at 4×70W RMS.
Has anyone know these units? Are there other plug&play DSP/amps in a similar price range that I should consider?
