CVX's or L7's???????
PS we have won 100x more SQ, and SPL awards with these L series drivers, then the round ones. So that is, clarity, loudness, and duarbility. But then again, we're just the manufacure, some guy in LA knows better...................//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Who is the target audience for the cvx? Just curious.
I was considering them because I only have room to seal a 12 or port a 10...I thought the cvx could stand sealed better than l7.
In comparison in KICKER...I see more blown L5s and L7s than CVRs. You can put your own meanings to what I say. I dont really care. I'm telling you what I see here at least once or twice a month.
You cant honestly tell me the square subs dont flex.....
I see RE, Fi, and others turning up more numbers than kicker.
By the way......why on the package is says "DESIGNED IN STILL WATER" and then "MADE IN CHINA"
the loudest guy in USACi, with a world record, from YOUR state, Matt Sibley did it with yes, sqaure woofers...Solo X's...
the best SQ car, in the world, is IN YOUR state, Corey Himel, Prestige, using, yes, sqaure woofers...L7's
Markey Dietrich, also, IN YOUR state...SQ....so for a short drive, you can be taught...
just because you see more blown L5's, or L7's, than CVR's is beyond me, but I can safely bet, if I cut open any of those, reading the suspention and coil, I'd show you why they were blown.
Roiund woofers don't flex under high pressure??? Surrounds on round woofers don't flex????//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
So you see RE and Fi turning up more numbers, what, is the small town your in, or across the US, or is this just what you 'read' on forums that now makes you a professional in your judgement?//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
everything, is DESIGNED by us, in Stillwater,we own the tooling,etc...then made elsewhere, like MANY manfactures...yea, even ones that DON'T make sqaure subs! New flash!//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
I bet you even where one of the original skepticals, in 2000, that the L7, put off 'sqaure' sound waves........................throw a sqaure rock into the pond, and watch the ripples. if they go our sqaure, then I'll bow down and ask for forgiveness, until then....believe what you want to believe.....//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
same power handling as L7, but will be an add on above the CVR...like L5, to the L7
Cheap labor? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
your new, to this GNP thing huh???I bet 90% of what you own, and wear, was made by cheap labor....you shouldn't be on the net now, you should be BACK in school...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
lawl
I watched Matt set records in '06. I think 3 of them. Street beat, and 2 others. It was at Ricky Smith's car audio. And I know Matt. I also know within that minute of play....the subs were almost toasted. The numbers were DECREASING. 3 to 4 dB in less than a minute. It happens, I know. ALL the time. How many times were they rebuilt?
And trust me....any ole average joe wont get the numbers HE produced either. That box he designed was superior, and it should be for the multiple days he worked HOURS on tuning that box and making sure it was perfect.
And that was from 3 SoloX 12s. If it was from L7s, the numbers wouldnt have been NEARLY as good, and they would have been gone within 15 seconds. And that's coming from him when I asked how well the L7s would do.
Anything further is useless.
|done.
Ur right, I'm wrong. Simple as that.
3 woofers used, all year, two new cones. Decreasing 3-4 db's, ever think of VC heat, amp heat, voltage loss being an issue??? And I too, know Matt
never said anyone could, stating facts, what the round coiled, sqaure cone does, your contradicting post
L7 max power handing, X power handling, totally diffrent, diffrent motors, everything...with the thousands of watts he had, der.....took the X's out and did an amazing number, same power he had on the Solo X's on CVX 10's, and never hurt one....
|done.
/thread
spoke my peace
boogerdawg
boogerdawg
Keyser, Wv
Lil Poot
