Current events discussion
the far left sure does like the 2A
No...you're talking out your backside now...there is zero wrong with open carry...unless it's against your politics...
If you want to be the first one to catch a bullet when sh** goes down, have at it, tough guy.
I suppose you think stealth airplanes are for the weak?
So open carry means catching a bullet...
How does hiding your gun in your purse make everyone around safer Rob?
It certainly increases the odds of you becoming a point of focus over others.
Like when you see the dude in hi his 5.1 tactical pants, with his tee shirt that has the 2A printed across the whole front and back, the paracord bracelet, big old deep-carry folding knife.
He's either carrying, or a wannabe. Either way, he is target #1. As opposed to the guy in Levis, polo shirt, Nike sneakers. And an XD AIWB.
Sure, you can reference the "blue sky" possibility that a criminal will change their mind when they see you open carry. But there are no stats to back it up. There is 100% proof that if you open carry, your gun is visible. And that makes you you different from everyone else who is not open carrying.
Different is BAD when the SHTF.
So, what is your daily carry? Why do you think open carry is better?
“As of Thursday, PBS affiliates across the country are airing a five-minute version of the controversial new film “SEVEN” directed by Dylan Avery, creator of the Loose Change series, about the findings of a recent University of Alaska Fairbanks (UAF) study on the Sept. 11, 2001, destruction of World Trade Center Building.”
1. How did they know 7 would be damaged significantly enough to be a good cover for this controlled demo?
2. Was EVERY building in the district wired for demo, and after all was done, they secretly DE-wired all of them?
3. I can melt 1/4 steel with charcoal and a hair driver. Why is it a surprise that thousand of gallons of burning jet fuel with the high speed air naturally created by intense heat couldn't burn steel in the tower?
4. Why do they misspell thermite so many times? Should experts who are claiming thermite use be able to spell it? (Thermate is for small areas).
5. How would they have snuck in the required thermite (100lbs per explosion point), set it up with remote triggers at every floor, done so without anyone seeing, and triggered them without making any noise?
And that's the tip of the iceberg.
Jimi77
Premium Member
CarAudio.com VIP
Jimi77
Denver, CO
ThxOne
