Crutchfield
  • 2
smokeoff
here's my 3 cents
1,114
Cambria,WI
On their site I went to the what fits my car section. They have the adapter ring to convert 6x8 to 5.25" But they say the polk ex3 won't fit. Is this because it is too deep or is it because the screw holes don't match up wich I could fix simply by drilling my own.
1997 Ford taurus Gl sedan
HELP PLEASE.
Originally posted by smokeoff About how thick should the plywood be
Well, that depends. If the woofer isn't going to fit because of the mounting depth, you should use a little thicker wood so it will have the clearance after it's mounted. If it will clear that back fine, then you can use like 1/4" or so.
smokeoff
here's my 3 cents
smokeoff
Cambria,WI
Randy Savage
    May 16, 2024
    May 16, 2024
