Crunk Times, My friend.....Crunk Times
Iam,
I am considering a 2.1 setup for the BR. I am thinking 4" tang band bamboo cone running rull range + 8" sub ported.
This 2.1 amp from PE does 50w for subs $ 4 ohm, 25w for speakas @ 8. I can use the audio out from a cheapass DVD player to make it work.
Or should I just get a "real" receiver and use it as a 2.1...meaning bi-amp the fronts and then get a nicer (10 or 12") sub.
The second option is a bit more expensive, and I don't know if you can use the channels in that way due to processing.
I like this: http://www.jamo.com/Default.aspx?ID=6358&M=Shop&PID=15706&ProductID=18073
as an alternative, and just do the sub later. My local person wants like $500 for it....but I am a fan of the sleek style for the bedroom, plus it's compact and "all-in-one".
I don't put much stock in BR setups, so your plan sounds solid and would give you the "I did it" factor over just buying something.
I don't know much about the bamboo cone but I was amazed at this driver when I used it in my center channel.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-818
It has nice midbass in the ported enclosure I built for the center. I used it in a 2 way setup though, so I don't know how detailed it is up top, but it is for the bedroom so it should be fine. I did choose it so I could use a high crossover point with the dayton planar I coupled it with.
I see the bamboo claims a higher response but the one I linked claims 14k and I doubt for your application the 20k response of the bamboo is necessary for $17 more per driver.
I am willing to bet you would be satisifed with the driver I linked. If not you can blame me and curse me out as not knowing shit for shit.
I don't buy into the 5.1 hype though...
I am looking for more of an aesthetic appeal versus good sound.
For movies, 5.1 is more than hype. For BR viewing though it is too much.
I don't know about the philips sound bar you post but some brand has something similar I heard in BB and wasn't impressed.
My bathroom habits have changed drastically in the past week or so.
Normally, I'll wake up, drop a deuce at around 8:15. Before lunch at work, I'll pee at around 1:00, and then drop another deuce at around 4:00-4:30.
Over the past week, I've maintained my morning droppage, but now find myself dropping another deuce at around 12:00-12:30 in the afternoon. Eating habits have remained constant.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Build up slowing and splitting the process? Perhaps a colon blow is in order. Please post results afterwards.
bdawson72
Finally Has Bass Again
bdawson72
434/804, Virginia 15's:Yezzir
▼)Ñ╩fZΣµ&
