Crunk Times, My friend.....Crunk Times
Indeed.....
I may go with this Mach5 stuff.
8 x 6.5s and 3 planers
His 6.5s would be great. you will still need 4 planars to achieve the 8ohm load though. 8/3= 2.6, 8x3=24, see it don't work //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif2x8/2=8ohm //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Should be able to get some decent midbass from the 6.5s
I mostly use my HT for video games...so subs aren't really needed
6.5s get kind of cost prohibitive when you need 16.
Perhaps these?
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-809
Although they will lack and midbass, but should be great for the music.
In essence, I need either 4 or 2 planers?
You need whatever will give you a final load of 8ohm to match the XOs. With the mids your load can be either 4 or 8 because the dayton XOs have a jumper for either load, but only do 80hm loads for tweeters. With the planars I linked to, you can use 1 or 4 for an 8ohm load. 2 would give you either a 2ohm load or a 16ohm load. So basically you need 4 in each lol.
I still can't find your post with the planars...
4 of these in each tower http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=275-085
Or get crunk and spend oober dough for 1 of these in each tower. http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-704 //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Except you would need a custom XO for that bigun. its 4 ohm. **** sexay though.
As far as worth it in cost, that is relative and I know money means a hell of a lot more to you than me LOL. They are definitely more suited for line array by nature. You could always use the same 3/4" daytons I did but just more of them and an attenuator. My tweeters only faults are the lione isn't tall enough to match the mid stage properly. The 3/4" daytons are cheap.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=275-030
An afro american pulled up behind me at a red light on campus today bumping his system. I rolled down my window, gave him a thumbs up, then proceeded to blast mine for several seconds. I then paused it, and heard him laughing and shaking his head.Then he gave me a thumbs up.
Does that make me Crunk?
Gah, this isn't the //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif thread
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
bdawson72
Finally Has Bass Again
bdawson72
434/804, Virginia 15's:Yezzir
▼)Ñ╩fZΣµ&
