Sold Crossfire VR2000D 2000w @ 12v
slam
Crossfire VR2000D
This is the newer crossfire vr2000d that has the fan inside the middle to prevent overheating.
This amp will operate at 12v though 16v. No modifications needed. At 16v this amp will put out about 3600 watts!!!
Includes:
Crossfire sticker
Manual
Birth sheet
Amp
Bag of mounting hardware
Original box and packaging
435 shipped
Below are some specs rated at 12v
MPN: vr2000d
Key Features
Amplifier Type: Mono Channel
Bridgable: Not Bridgable
RMS Power at 4 Ohms: 1000 W x 1
RMS Power at 2 Ohms: 2000 W x 1
Performance
Frequency Response: 5 Hz - 250 Hz
Signal to Noise Ratio: 90 dB
THD at Rated RMS Power: 0.08 %
Other Features
MOSFET Circuitry: Yes
3 Way Ready: No
Dimensions
Width: 9.3 in.
Depth: 22 in.
Wish I had the money. Id love to try this on my 16v setup...always wanted to try a crossfire:)
These were ran per coil on 3 crossfire 15's hitting a 163+
ALSO.........
Im willing to trade for more batcap's, 40.1's and more knu flex wire(greyish black)20' or more. I have monies to add
at 1 ohm these things do a lot more then 2000 watts on 12 volt systems too.
I clamped 2800 out of mine at .7 rising to 1.4.
And we clamped 4500~ out of cooks on 16 volts at 1.4 rising to 2.8
yes these will go down to .7 but i wouldnt recommend it going ne lower.
these are some best at 16v for sure
I ran a couple of mine at .25 before and had to roll into it but gained another 7 tenths over 1 ohm.
I never clamped it at .25 though...but these amps are some of the most solid built amps ever
I miss mine
slam
slam
fort worth, tx
slam
ThxOne
    May 13, 2026
