critical mass UL-A2500 V2.0 any info?
For the specs it seems over priced. You can find similar spec'd amps in the classifieds for a fraction of that.
Critical Mass UL-A2500 V2.0
Specifications:Frequency response 9Hz~250Hz
RMS power at 4 Ω mono 1320w
RMS power at 2 Ω mono 1950w
RMS power at 0.75Ω mono 2520w
Max power 3000w
T.H.D 0.01%
Input sensitivity 200mV~8V
Input impedance 92K Ω
Damping factor >520
S/N ratio 105dB
Max power 3000w
T.H.D 0.01%
Damping factor >520
S/N ratio 105dB
the v2 will do like 1800 at 1ohm, and personally being a person that has used a lot of CM stuff, I would look elsewhere. If you burn it, they will charge you your left nut to fix it. and your left nut = more than you paid for it in the first place
yea i figured the company was full of b.s to start they are over priced for sure not to mention all the celebrity are they really using the stuff or paid to advertise? i was considering the amp because i put a bid on a new one on ebay and i lost it but the seller sent me a second chance offer so i wold pay 465. shipped but the more i looked into it the more it looks like a massive audio nanno n4 so i decided not to but it just wanted to say thanks for all the help.
cal
cal
kmanian
