Sold Crescendo 1000C4
undeadxsunshine
what it is
1. Product:
Crescendo 1000C4
The Crescendo 1000C4 4 channel amplifier is the ideal amp for your mids and highs, while still able to do a hefty 500 watts x 2 bridged, perfect for many subwoofers and high power capable mid-woofers. Featuring class-AB topology and high end components and workmanship, this powerful 4 channel amp is a perfect choice for anybody wanting a proper sound stage to keep up with the bass, while still able to produce all the nuances needed for a sound quality optimized setup. Quality and Power all in one heatsink.
2. Specs:
Power (RMS) at 13.8volts:
125w x4 channels at 4 ohms
250w x4 channels at 2 ohms
500w x2 bridged at 4 ohms
250w x2 bridged at 8 ohms
Features and specifications:
4/3/2 Channel Class-AB Bridgeable Amplifier
Optimized PWM Power Supply
Fully stable into 2 ohms stereo and 4 ohms bridged
18db/Octave Variable Crossover Slope High Pass Filter with HPF/FULL/LPF Selection (1 for each stereo channel pair) (50hz to 1khz)
Low Pass Filter with HPF/FULL/LPF Selection (1 for each stereo channel pair) (30hz to 250hz)
Full Comprehensive Multi-way protection Circuitry with Status Light Indicators
Ultra Wide Frequency response: (10hz to 40khz)
Signal to Noise Ratio: >90dB A-Wieghted
Total harmonic Distortion: .05% at 4ohms
Operating Voltage: 9.5V to 16volts
Wired Remote Gain Controller, Blue status light
Fuse Rating: 30A x 3 Parallel delayed
Dimensions:
Inches: 9.7(W) x 2.4(H) x 16.9(L)
mm: 247(W) x 61(H) x 429(L)
3. Description/Condition:
Heatsink is in almost perfect condition. Only been used a few weeks at most. I just decided I only need a 2 channel amp.
4. Price: :
180 shipped firm
undeadxsunshine
what it is
undeadxsunshine
York, PA
undeadxsunshine
