crackle
ccaps83
21
ny
put new s[eakers in. i have factory head unit in alero. deffinantly hookd up correctly. polk 4x6 mommo. 50rms i knw the head unit isnt strong enough for them but the car already had aftermarket speakers in and they didnt crackle and my rears still dont crackle, is it just cuz these polk are double the power then the old ones? should i worry that they are bad speakers i bought brand new. when ur turn volume down they stop crackling. any help thanks.
then they are definitly not hooked up correctly
u dont think its just cause they are 50rms speakers with a factory headunit? plus the issue that they car has factory tweeters just taking even more power.
well lets make sure, i checked the wiring and everyone told me for alero
LF Speaker +/- tan - gray +,- radio harness
Notes: If equipped, the amplifier is in the driver side on the trunk.
RF Speaker +/- lt. green - dk. green +,- radio harness
is this incorrect i follwed these guidelines.
so can someone who knowes for sure let me knw what is positive and negative for the front doors on a 04 alero?
why would them being connected backwords cause them to crack i thought cracking or clipping was just a power issue? idk tho again my other aftermarket speakers didnt crack or clip.
so ill probably also hear a little more bass also then when they are put back in phase then again cant much be coming from a 4 inch speaker.
If you are using a stock head unit, you might be clipping the amp because most aftermarket speakers have 4 ohm coils and most stock HUs run at 8ohms IIRC
Agreed.
I've only experienced crackling with stock head units, or bad wires/rcas.
I see common sense evades some still.
Someone almost hit the head on the nail.
What you got here is your replacement speaker is 4 Ohms and you have the factory tweeter wired in also (its a 4 Ohm). So you have the headunit bridged. You cant do that, period.
Your speaker will operate no different in phase or out of phase outside of the phase shift. Anyone who says anything different obviously has no place answering technical questions.
BTW see you on the Alero board!
ccaps83
ccaps83
ny
Ryan from Ohio
