yes a countersink bit helps or coarse (spelling) drywall scews and and predrilling with a good power screwdriver.Real quick just wanna know what do you use to countersink screws? I'm thinking my answer is a countersinking bit,not for sure though.
http://www.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_diy.jsp?CNTTYPE=PROD_META&CNTKEY=misc%2fsearchResults.jsp&BV_SessionID=@@@@1750962993.1147501426@@@@&BV_EngineID=cccdaddhkhfgkdgcgelceffdfgidgng.0&MID=9876
you use it to drill in to the wood.
then you drill teh screw in
Any bit that starts the hole, something that is 50 % smaller than the screw is goodIf i'm using a 1 5/8" coarse drywall screw,what size drill bit should I use?
i used a 1/8 drill bit for 1 5/8th screwsIf i'm using a 1 5/8" coarse drywall screw,what size drill bit should I use?
Use a bit that is the same size as the actuall shaft in the center of the screws. So you dont want it to tbe the same diameter of the screw with the threads.If i'm using a 1 5/8" coarse drywall screw,what size drill bit should I use?
lol noobAs do I. I also never "countersink" as my drill has enough torque to do it for me.
