Cooling The Coil
just run a hose from your AC into the box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.. ya you should be able to put some more to it and get better numbers
heat is going to dissipate outward, blowing a fan at it on one spot isn't going to help.
lulz.
Who said i was going to direct it at one spot. You're my boy but you need to keep your ignorance outta my shit.
I have an air hockey table outside with a sick fan on it.
How is it stupid. Thermal power failure is a big thing that blows subs, you put too much power and it frys the coil. If thinking logically, if you can keep that coil cooler then you can put more power to it. It seems like a perfectly legit idea to me.
Im not sure about the life of your subs but cooler coils = bigger numbers period. I said what i said because i know people that are serious into it alot more then i am run AC hoses into their boxes... It would only make since this would help the subs last longer... but i dont know about a fan
**** that... just spray it with a nitrous purge, that will cool it down.
If you're blowing cool air on it, where is the hot air going to go?
There are competitors who will put 10kW or more to a sub. I'm fairly certain no one has tried this, because there's no point.
Whats the flash point of NOS and how hot does the surface of the coil get. Not to mention a steady flow of electricity could easily equal and explosion. An evenly sprayed jet of air around the coil at the velocity that this fan can product should yield very good coil cooling with the open design of the motor of everything.
The hot air would be expelled out so if the motor isnt completely encased the the hot air most likely would just go out of the box through the ports. Im sure i dont have enough power or anything where i would notice a major gain but this seems like a very solid and defiantly logical idea.
Johnny Law.Lulz
Banned
Johnny Law.Lulz
Virginia
audioholic
