Cooling Fan - In or Out?
AlterEgo99
Streaming consciousness
OK, here's a "which came first, the chicken or the egg question"...
I installed a 3" super quiet 12 VDC cooling fan in the lid of my center console. It's nice and hidden and blended into the interior quite well. There are 2 Alpine PDX amps in the console, 1 is an Alpine PDX 1.600 and the other is an Alpine PDX 4.100. They are stacked.
There are three one inch holes inside the "box" (console) so that I could get the power wires and speaker wires to the amps. So, these holes are also adding some ventilation. Even though these two amps are Class D, they can get a bit warm inside that console with the top cover shut, which is the reason I installed the fan. Now, the big question...
Should the fan be blowing OUT to remove heat as it is generated from the amps OR should it blow IN so that cooler air from outside the console is blowing over the amps/heat sinks.
What say y'all????
Let the battle begin! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
If the fan is up high I would make it blow out. but you can play around yourself by putting a thermometer in there and try both ways. out just makes sense to me if especially if the fan is up hing on the lid. heat is going up then forced out quick. just make sure you have open intakes down low to let cool air get sucked in. Blowing in would just blow hot air back down at the amps
I agree with that too. If you have vents at the bottom to let in cold air while the fan is pushing out the hot air will create a good circulation.
Out it is then...as it is at present...as it is located directly above the amps that makes sense! Thanks everyone for the input...and no, I'm not gay. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
since you have 3 why not put one on the bottom blowing in cool air and leave 2 on the top blowing out? would get more airflow than just the little bit of room around your wire holes.
AlterEgo99
AlterEgo99
Domie Homie
Reborn
BP1Fanatic
BP1Fanatic
