billybrown66
i've been looking at purchasing a new hu for a while now and seeing that the kenwood XXV-01D is now on sale at crutchfield i'm looking to pull the trigger. the problem i have is that i'm using an raa4200 for my components up front (running passive) and was looking to use the built in amp on the kenwood for my rear speakers. when talking to a crutchfield employee they said...
"The problem is that you will be tempted to turn the system up to match the output of the amplifiers. This might cause the internal amplifier to clip. You will have to use the internal amplifier as the defining output level. ...using the Kenwood internal power may limit how loudly you can play your system, and the solution is adding an amplifier"
i already have two big mb quart amps in my car i dont have room for another amp nor do i want to run one. does anyone foresee a big problem with using the built in amp on the hu for rear speakers while using an external amp for my fronts? also if anyone has used this this kenwood, was there a noticeable difference with the internal amp turned off as opposed to on?
