OP
Mattman00969
- Thread Starter
- #16
Ok, I got it solved.
I took apart my whole wiring and used a test light to see if everything was good.
I first checked the ground wire to the positive batterty terminal, and it was good.
I then checked the remote wire when the Hu turned on and it was getting a good voltage as well.
I then checked the power wire, and I wasn't getting any power (Ah ha! a clue!!) I checked the wire at different areas, and found that it would work before the in-line fuse, but not after. I took the fuse out, checked it, and it looked perfect. Put the fuse back in, tried it out again, and got power. Tried out the amp, and it worked...but only for about 5 seconds. tested the fuse again, and it wasn't getting power this time. I went to the store, bought some new fuses, tried it out, and it worked, for good this time.
Now the problem I'm having is now that I have the bump in the trunk, my 12-disc changer skips on every hit //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif . Oh well, if it isn't one thing its another.
thanks for everyone's help, you were all eally helpful.
