connected a DJ amp to 2 12''s , not as loud as I thought...
mrpep
So I got a hold of a peavy cs 800x
Peavey CS 800X 2 Channel 1200 Watt Professional Stereo Power Amplifier | eBay
http://www.manualslib.com/manual/121470/Peavey-Cs-800x.html?page=3#manual
and connected 2 x 12'' Rockford punches , 1 to each channel. I can max out volume and the woofer sounds good but does not move like it could. They are both 4 ohms and the woofers are 400 rms.
Rockford Fosgate HE2 RFP4212 12" Dual 4-ohm Voice Coil Component Subwoofer at Crutchfield.com
What can I do get them most out of this set up? What am I doing wrong?
Its possible your source signal isn't strong enough. I use a 1.5KW amp here bridged to 4 ohms in my home theater. The surround receiver its connected to has to have the Sub out maxed out and the amp cranked pretty high to get proper power.
so how should I wire them?
Box plays a big part too. If you have them in a premade box, then you wont get anywhere near the optimal performance even if fully powered.
I love the picture but are you guys sure the amp can run at 2 ohms?
So I wired this way and the old boxes could not handle and are seperating. I basically replaced my old cerwin begas with the RFP4212 Rockford punches.
Vintage Cerwin Vega at 12 AT12 Speakers Brand New Foam Super Nice | eBay
The speakers are from 1989 and the foam fell apart. Many will say refoam but to be honest they were not as good as todays speakers. Anyhow, rewiring made a huge difference but what it is really boiling down to is I need better boxes.
mrpep
mrpep
chicago
mrpep
