Sold Complete Sundown Audio setup
on1wheel01
Bang A Lang
1. Products: 1 18" Sundown Nightshade D2, 1 saz2000d , 1 4.8 cubic ft box tuned to 33 hz.
2. Specs:
* Digital Class-D Linkable Mono Block Amplifier
* Double Sided Through Hole Epoxy PCB
* 1 Ohm Stability
* Daisy-Chain Through Output RCA
* Efficiency : 86% @ 4 ohm, at 100Hz
* 24dB/Oct Variable Crossover
* Multi-Way Protection Circuitry
* (Thermal/Over Current/Speaker Short/Speaker DC Protection)
* RCA Line Input and Master Output
* 24dB Octave Crossover Slope
* 24dB Octave Variable Subsonic Crossover Slope
* Variable Bass Boost
* Variable Low Pass Filter
* Variable Phase Shift
* Zero(0) Gauge Power Supply Connectors
* Tested Voltage & THD : 14.4V & Less than 1% THD
* Operating Voltage : DC 10V~18V
* Wired Remote Controller
* MSRP $899 USD
* Dual 2-ohm or Dual 1-ohm Voice Coils Available
* 3" Diameter 8-layer flat-wound Aluminum Wire Voice Coil
* High Temperature Aluminum Voice Coil Former
* 1500-Watts RMS Power Handling
* Over 2 inches peak to peak excursion
* Wide, triple-layer foam surrounds for high excursion
* Extremely strong paper cones w/ stiffening disc
* Thick poly dust caps
* Cast Aluminum 12-spoke basket with cooling vents
* Triple Stacked 1" x 9" magnet slugs for high motor strength
* MSRP - $729 USD
T/S D1 **:
RMS: 1500
Z: 2 ohms
Re: 2.09
Fs: 35 Hz
Qms: 9.9
Qes: 0.58
Qts: 0.53
VAS: 82.88 L
BL: 18.98 NA
T/S D2 **:
RMS: 1500
Z: 4 ohms Re: XX
Fs: XX
Qms: XX
Qes: XX
Qts: XX
VAS: XX
BL: XX
3. Descriptions/Condition of all items: The Nightshade is in great shape has only been pushed by the 2000d with gains set with a dmm never clipped good electrical to back her up. Saz2000d only a few months old still tons of warranty left. And the box is made of birch nice and strong. All work perfect no issues. It's just thisset up is destroying my car so it's gotta go.
I will not I repeat will NOT separate all or nothing
4. Total Price: :950 obo
Possible trades for hell i dunno not to interested in audio as it's causin the problem
5. Pictures:
No thanks the 2000d is worth much more than that. Also it is now traded. I am now selling or trading my 18" sub. I am doing 2 12" cascade omega d1's and 2 saz1500's. I already have one sub and both amps. Now just need one more sub.
on1wheel01
Bang A Lang
on1wheel01
Mooresville nc
on1wheel01
