Community For Sale Ad/WTB for Me
tapout
This is technically a WTB thread for me but its also a chance for you to have your FS items(amp, subs, comps or HUs only) in a second thread.
Whatchu got? Post it up....
Things I'm looking for...
I found what I need, but feel free to keep this thread alive.
If you want to sell it, then sell me(others). Post pics and specs. Dont make me do your work. Someone else may even contact you about it which is the purpose of this thread.
To others looking to buy: treat this thread like any other. DO NOT post dump on someones items or prices. Feel free to comment and ask as many questions as you like. See something you like, buy it. Hope this thread helps me and you.
i have a poweracoustik ps1-5500d 10/10 looks, 10/10 working condition , used only for 3 weeks at 1ohm never played with car off, seen 13.2 volts at the least.. mfg specs.. 1700rms @4 2500 rms @2 3200 rms @ 1 have orignal box, paper work, remote and remote wire along with sync cable to strap with like amp. asking $300 shipped also posting gut pics to show its not blown and also to finaly put guts up of the 5500d
also memphis audio eq50 eq. 5 bands 7/10 looks 10/10 working condition
asking $50 shipped
Thoughts on real world output?
Well being as I can't find another 3512, and I'm really wanting something different than my Juggernaut I've decided to try selling them.
First off I have a 15'' d1.4vc MMATS Juggernaut. It's an awesome sub, and is very similar to the early 9500 series subs. There are acouple flaws on the motor, such as the boot has shifted alittle, it's missing alittle strip of rubber on it, and there are some scratches. Mechanically it is 10/10, and will take tons of power.
Next, I have a 12'' d4vc Digital Designs 3512 D. Another great sub, wish I could've found another //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif. Anyways, when the sub was shipped to me, usps did not handle it with car and something poked through the box and made a slit in the surround. I epoxyed it and the subs works fine now, just has the shiny glue from the epoxy on the surround, and a couple little nicks where it was mounted before.
As for prices I would like $280 shipped for the MMATS Juggernaut, and for the DD 3512, because it is damaged, i would like $220 shipped. These prices ARE OBO, but NO lowballing.
Thanks,
Jonathan
i dont know how to detrmin the real wattage instead of doing the amps x volts x load but i have been told on other fourms *roe* a guy said he had tested one doing 2880 watts
I have a BNIB Sundown 100.2, 100.4 and a Eclipse 8454 HU that was installed for maybe 3 months. It looks brand new (original box, harness, cage, remote and ect..).
I have the following for sell or Trade, pics are here: http://www.caraudio.com/forum/showthread.php?t=269120
MTX Thunder 502 2ch. amp $110 shipped
Amplifier Type Dual Channel
Bridgable Bridgable
RMS Power at 4 Ohms 90 W x 2
RMS Power at 2 Ohms 180 W x 2
Performance
Frequency Response 20 Hz - 20000 Hz
Signal to Noise Ratio 110 dB
THD at Rated RMS Power 0.1 %
Crossover / Equalizer
Bass Boost With Bass Boost
Bass Boost Frequency 40 Hz
Low - Pass Frequency 40 Hz - 200 Hz
High - Pass Frequency 40 Hz - 200 Hz
Other Features
Input Voltage 12.5 volt
MOSFET Circuitry Yes
Dimensions
Width 12.6 in.
Depth 9.75 in.
Height 2.1 in.
Audio Control EQx $115 shipped
Dual-bandwidth Equalization with Crossover
6 Band, 1/2 Octave Bass EQ
7 Band, Octave Equalizer
Two-way 24dB/Octave Linkwitz-Riley Crossover
Programmable Frequency Match (PFM)
Subsonic Filter
Line and Speaker Level Inputs
Balanced Inputs
Input and Output Level Matching Controls
Boston Acoustic S60 Components $70 shipped (no grills)
Nominal Size
6-1/2" (165mm)
RMS Power Handling - 55w
Peak Power Handling - 150w
Frequency Response (±3dB)
58Hz-20kHz
Impedance - 4ohm
Sensitivity (1 watt (2.83v) at 1m) - 92dB
Mounting Depth - 2-1/2"
Prefab Dual Sealed Enclosure $15 (local pickup only)
4ch. Power Acoustik amp A600-4HP $70 shipped (matches mono DB series amps)
RMS Power Output: 85 Watts x 4 @ 2 Ohms
Birdged Output: 600 Watts
Signal To Noise Ratio: 97 dB
Frequency Response: 10-30,000 Hz
Bass Boost: 0-18 dB
Built-In Crossovers: HP / LP
THD @ 4 Ohm RMS Power: 0.02 %
Low Level Input: No
Built in Cooling Fan: No
Bass Control Knob: No
Dimensions: 11.25 L x 11 W x 2.3 H
Like new LG 160W Compact DVD Shelf System with USB Port
Model: LFU850 $100 shipped
tapout
tapout
Ga
Beerdrnkr
