85Caprice4d
((First off, the biggest thing I need help with is amp selection, tweeter slection, and midbass selection, and i would like to keep it under 600 if possible.))
I just got a job again, so Im planning out what I am going to do.//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
I have alot of ideas for my caprice. I just ordered a dash install kit from best buy for a 1985 caprice classic. That only set me back $20 so I was thinking I would do my dash custom soon. I was thinking of measuring out a peice of sheet metal which I could bend into a small arch. I want to take out the stock heater controls and have them redone and organised on the Sheet metal arch. Then I want to make the space below the heater (stock was a 2din size am/fm tuner) into 2 custom 1din spaces(to do this I might have to extend the whole space and move down or take out the ash tray). I then want to put a new h/u in (and maybe an equilizer if I can afford it). Then I was thinking of making a fiberglass center consol to fill the space in between the driver and passenger side leg spaces. Then I want to take out the two vents on the farthest sides of driver and passenfer side(or mount in close proximity to) and put in a tweeter on both sides. Then I want to re-do the stock rear deck with two good s/q midbass or just higher quality 6x9's.(I was also thinking of swapping out the back seat for one with an armrest in the middle that when folded down leads to the trunk). I also want to take out the stock analog clock that sits dead center in the dash, and put in a digital spedometer and cover it along with the vents on both side of it with a fine cloth style mesh.(so the only time u see the spedometer is when the car is running and the light is lit up.)
Eventualy but probably rated low on my to do list, I want to tint my windows with the shiny silver/black faded tint. (I dont know a good percent but I want the h/u and most of the dash hiddin from outside.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
For the trunk, I want to rip all materials out, paint the metal so it matches the outside, then put in the subs and amps. For subs I plan on buying two Elemental Designs 13Kv.2 D4.((http://www.amazon.com/Elemental-Designs-13Kv-2-D4/dp/B000EGAMNU)) For the amps, I dont know much on how to determine what amp will be best for the subs, so If anyone has any ideas, I want a clean (plain and simple in visual style) amp for both subs. Then I was woundering if I will need an amp to run the tweeters and midbass. before I install subs and amps, I want to build a custom amp rack that will hide the amp(s) and any visable wiring with a hinged door. I want to have the sub box(which i still havnt decided on, but a 2 12" square box) to sit in a fitted cutout from the amp rack that will be about 1-2" deep(to prevent sliding without fascets).
Eventually I plan on redoing the dash, which will include repainting it the stock blue, putting diamond plated, or brushed steel where the cheap stainless steel looking crap is now, puting a digital spedometer in the center of the dash
, h/u install, mesh over all vents and new spedometer,//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif and possibly center console as an addition.
After I get most of the speakers, dash, and trunk install done, I want to put a new peice of blue carpeting in on the floor, because the one in it now has some tears and faded scrapes in it, and possibly replace the fornt "split bench" With 2 comfy seats(so i can continue the center console to go in between them.)
I also need to remove the apolstory on the inner roof of the car, (my friends all played with it, and I told them the adheisive would come off) and replace it with new shit, same color.
After all of this is done, I guess I dont know what I really want to do as all the major problems with body work will be getting fixed during all of this which will include;
4 new fenders
4 new doors
new brakes
tires/rims
exhaust
put in a performance carberator
spark plugs
altinator
battery
front end alignment
shocks
struts
tie rod check
and alot more under the hood.
so I need help in slection with:
amps
midbass
tweeters
small(1"x2.5" ish) rectangular digital spedometer
h/u
speaker box
and appx cost of wiring if I use all 0awg for grounding, power, and the big3.
battery
altinator
dash paint
//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif :greedy: //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
I guess I could start working on my tough guy look when I drive next to people with my window down, but maybe thats getting to far ahead of ourselves eh?
4 new fenders
4 new doors
new brakes
tires/rims
exhaust
spark plugs
altinator
battery
front end alignment
shocks
struts
tie rod check
amps
midbass
tweeters
h/u
speaker box
battery
altinator
dash paint
