CMPX2 15 or DD 9012
CMPX2 15 or DD 9012?
  • CMPX2 15
    Votes: 5 83.3%
  • DD 9012
    Votes: 1 16.7%
  • Total voters
    6
CrAiZ3
Hey guys. Im switching from SPL to SQ and don't know to much about these two woofers. I am switching from an audioque HDC318 and am looking into the CMPX2 15 and DD 9012 right now. Just am wondering which will best suit my needs.
I still love SPL. I've always loved the loudness but the 18 just isn't a good daily driver for me. I really want something that will put off a good bit of db, but also to hit every beat, sound clear and amazing. Also, any recomendations on which way to go on a box (ported vs. sealed) would be appreciated too. Right now the audioque is in a 7.6cuft @40hz. I would have no idea what to tune either of these subs to.
Also I have a Fusion Powerplant PPAM200010 and wanna know which sub (if either) would work best with it
Bass Boost @ 45Hz: 0-12db
Frequency Response: 20Hz - 350Hz
Fuse Rating 40amp x 3
Input Impedence: 20k
Input sensitivity: 0.2v - 8v
Max Power Rating: 2000w
RMS Ratings Per Channel:
600 x 1 @ 4ohms
900 x 1 @ 2ohms
1000 x 1 @ 1ohm
Variable Low Pass Filter: 6db / Octave
Dimensions: 436mm(L) x 278mm(W) x 60mm(H)
Amplifier Class: Class D
Variable LPF (35Hz-350Hz)
Any help is appreciated.
Thanks.
Dan //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
I'd do a pair of 15" Dayton Reference subs in a shared 7ft^3 sealed box. You still get a good amount of output because of the cone area, and good transient response a well as good low end extension with the sealed box(sub with have a f3 of around 30hz out of vehicle).
this would be sweeet
CrAiZ3
CrAiZ3
Pittsburgh, PA
CrAiZ3
