YungGunna313
Ice 'N Bedford
ok dont flame me for not doin a search just please read my question...
i got a pair of subs & an amp off my boy for pretty cheap $400. two audiobahn alum12q's, and a pg octane 15.0:1. now my question is about the amp mostly but it has to do with the subs.
the pg is rated 750 watts rms x 1 @ 2 ohms. it is a mono amp, but the amp has 2 positives and 2 negatives. i dont have that much experience with mono amps, so if i wire the alum's up to 3 ohms (each sub getting one + and one -) would each +- give me 750 watts @ 2 ohms? i kno im getting less when i wire it to 3 ohms but im curious bout how much power will be put out totally.
so to the clipping. if each +- doesn't put out 750 watts @ 2 ohms, then it would probably be like 375 @ 2ohms to each sub right? (again itd be less cuz itd be 3 ohms) if that was the case would i be able to clip the amp to get the most out of the subs? i kno they are rated 1000 watts a piece, but from what ive been told they would be better off only gettin around 700-800 cuz they are overrated. i dont kno just what i heard.
so i guess to sum things up (yea i coulda saved some time by just makin it quick), if the amp doesn't put out 750 watts @ 2ohms for each +- for the speaker channel, would i be able to clip the amp to get the most out of my subs?
i appreciate any help
