dustyshot
Ok, I have a question. I have used different amps and they would go into protection even when gain setting was 1/4 or higher. I also got a sony xplod cdx-gt130 deck with loud setting on it, and I got it enabled. Is this loud enabled clipping the amp? should I just disable the "Loud" on deck and up the gain a little bit. With loud on it hits volume 20 and sounds good, but anything above that it sounds like more highs and bass does not change to much. So I think that turning loud off would fix that so when I do go above 20 volume it will increase bass too. The max on this deck is 50 volume. So I think the loud is limiting the volume control on the deck. Em I correct?
