clipping amp, help!
boostdfoci
NJ
Original set-up was 2-8" Ed subs 4-0hms, then moved to 3-8"subs running 2.67 ohms.
When I moved from the 2-subs @ 4 ohms to 3 @ 2.5 ohms, my amp starts to clip at hgiher volumes 15+. Does this mean i need a better amp? My amp is the eclipse XA-1000 rated @ 4 ohm 1% THD 320 watts, 2 ohm 1% THD 480W, the ED 9KV@ requires 200 RMS.
I put on ohm meter on my wiring into my amp and it reads 2.5 ohm.
boostdfoci
boostdfoci
NJ
///M5
