cliff desigsn cdx-10a
Specifications:
RMS power @ 14.4V:
4 ohm 750W
2 ohm 1000W
1 ohm 1500W
Max power @ 14.4V
4 ohm 1000W
2 ohm 1500W
1 ohm 1800W
Signal to noise ratio: >96dB
Frequency response: 10-350Hz
24dB low pass filter: 50-350Hz
24dB subsonic filter: 15-50Hz
Bass boost control at 45Hz: 0-18dB
RCA input sensitivity: 0.2-8V
Low level input impedance: 22K ohms
Damping factor: 200 @ 4 ohm
Fuse rating: 40A x 4
used has its share of scratches , however works as it should all the lights, gauges and fan work as well and no stripped screws.
i bought this off a caco member for a friend and he flaked . wish i had use for it but im into 7-12k amps so its got to go
165 shipped in the u.s.
Specifications:
RMS power @ 14.4V:
4 ohm 750W
2 ohm 1000W
1 ohm 1500W
Max power @ 14.4V
4 ohm 1000W
2 ohm 1500W
1 ohm 1800W
