1) Clarion DXZ765MP Head Unit (Refurb, like new w/ box) - *** SOLD ***
http://www.clarion.com/us/en/products/2006/audio/source_units/cd/DXZ765MP/us-en-product-pf_1134643389116.html
- refurbed unit off ebay, purchased as a temp replacement for an ailing pioneer deck I had run for nearly 10 years. used for maybe a couple of weeks until I
upgraded to another deck. I didn't use it much in that time, but all seemed to work fine. i did NOT use the internal amp, but would assume it works fine as well.
2) Autotek Street Machines SX-2150 amplifier - $100 SHIPPED
- Not very familiar w/ the autotek line, but this one is from around 2001 I believe. I had a SS ref300 getting repaired at the time and picked this up as a temp
replacement. This packs a pretty good punch bridged. In very good condition, I'd say 8 or 9 / 10.
Specs:
• Full MOSFET Circuitry
• Fully Adjustable X/Over 12dB per octave 2 way- crossover
• Regulated Power Supply
• True 2 Ohm MONO
• 0-18 dB Variable Bass Boost @ 43Hz
• Adjustable Line Outputs
• Therma-Cool Heat Sink Design
• 4-AWG Molded Terminals
• Chrome-Finish Heatsink
• Chromed Front & End Panels
• Maxi Fuse
• T.H.D. .02%
• Signal to noise ratio 90dB
• Frequency response 10Hz-40KHz
• Input Sensitivity .2V-10V
• Remote Level Control
Power:
2 X 100 Watts RMS into 4 Ohm
2 X 150 Watts RMS into 2 Ohm
2 X 200 Watts RMS into 1 Ohm
1 X 300 Watts RMS into 4 Ohm Mono
1 X 400 RMS RMS into 2 Ohms Mono
Fuse: 30A
3) Diamond Audio D5 300.4 amplifier (with manual and original box) - $110 SHIPPED
- flexible amp, can do active. I just replaced this w/ an old phoenix gold ZX amp, so it's the odd one out. Very good
condition, 8 / 10.
Specs:
Technical
• Fully Regulated Power Supply
• Up To 5V RMS Input Signal Voltage Capability
• High pass x-over 12 dB/oct. 15 Hz-1.5 kHz
• High pass multiplier (x 10)
• Low pass x-over stereo 12 dB/oct. 50 Hz-5 kHz, mono (Ch 3/4) 24 dB/oct. 50 Hz-5 kHz
• RCA Outputs
• 2 oz. Silver Plated Copper Circuit Board
• Massive Proprietary Heatsink
• Frequency Response:10 – 50,000 Hz
• Signal-to-Noise Ratio:100dB
• THD:0.03%
• Channel Separation:80dB (min.)
• Input Sensitivity:.2 to 5V RMS
• Input Impedance:>20k Ohms
• Power Supply Operating Range:11 to 14.5V DC
Power
37.5W x 4 @ 4 Ohm Stereo
75W x 4 @ 2 Ohm Stereo
150W x 2 Bridged @ 4 Ohms (minimum impedance)
Fuse: 60A
Dimensions: 12 1/2" x 12" x 2 3/4"
Specs:
• True 2 Ohm MONO
• Maxi Fuse
• T.H.D. .02%
Power:
Fuse: 30A
condition, 8 / 10.
Specs:
Technical
• RCA Outputs
• THD:0.03%
Power
Fuse: 60A
