Clarion cz702e
2wd
14
Denmark
Hi
I have an old Clarion HU witch I bourght online but when I I received it, the 16 pin connector with ISO plugs wasnt there ... but I have a 16 connector from another Clarion HU (dxz828r) who fits but Im not sure if pin numbers/wiring are the same and dont want to damage the cz702e unit.
Anyone have picture of an cz702e 16 pin connector, wiring, pin numbers or something else that would be usefull rewireing it to work ?
Regards Tom, Denmark
well its not that simple .. I cant find any pin numbers on the 16 pin connector I have ... in the cz702e papers I have it says the following :
1 batt + 15A fuse
2 ground
4 Acc +
5 phone mute
6 amp remote
7 illumination
9 rl -
10 rl +
11 fl -
12 fl +
13 fr -
14 fr +
15 fl -
16 fl +
So I dont understand as I would expect that power and ground would be on either pin 1 and 9 or 8 and 16 as those are used on the dxz828r plug I have and also when googled, those pin numbers are used on the few drawings I've found ... only thing is that I cant find a picture showing the 16 pin connector for the cz702e ... ?
I know.... but I'm worried about the lokation of the wires as the papers I got with the cz702e have the batt+ and ground placed "different" ?? Any chance that you got the connector diagram for the cz702e 16 pin connector ?
Yes I know..In my papers there is a pic of plug A, B and C. I take that A and B are ISO connectors and C is the 16 pin HU connector. But I'm confused over the 16 pin connector...the pin numbers are different from what I expect.
I would think that +12v batt and ground should be om the 2 "big" pins in the end of the connector (8 and 16) but on my papers it says pin 1 and 2 ..? And then again it comes down to the connector and how thepin numbers are .. and I cant find a picture anywhere where it physically shows a plug with pin numbers ??
But I have two 16 pin connectors, who fits my cz702e HU, from other clarion HU's where the +12v batt (yellow) and ground(black) are placed as expected in the end of the connector on the "big" pins. Also I've found drawings of 3 - 4 clarion 16 pin connectors where +12v batt and ground are placed on pin 8 and 9.
So yes I'm a bit confused :)
I am out of state, but when o return i will take a photo of my plug.
Its the same as its european version.
Im sorry i had fully forgot to take the pic. I got back 2 days ago.
Just took them now.
Top of connector
Bottom of connector
Hi..super... your HU .. was that a cz702..?
anychance that you can find me the color codes and maybe pin numbers for your connector as they are a bit different to mine ?
for one, the pink lead, third from left on your connector, is red on my connector...and second from right is free on yours, on mine there is a yellow lead...and the third from right on yours is red...on mine its orange with white stripe....
So if you coul help on this too it would be super :)
Looks similar to this: https://www.sonicelectronix.com/item-17681-Clarion-CX609.html I'd call Sonic Electronics and see if they have what you...
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
I dont think anyone can answer that question of if a BTooth adapter will sound as good as a CD? Only one would know by actually using the same...
988
I would recommend to get on F.Book @ Old School Stereo and run a Want To Buy thread there. Im sure someone is hoarding one, maybe even a BNIB one...
I know what you mean ....its a pain going in all those menus ...i think kinda look at these new decks like old school trunk mount processors...
2wd
2wd
Denmark
2wd
    May 22, 2024
    May 22, 2024
