Clarion Pro Audio Amp APA5241
Specs-(remember, this is tested at 12 volts, not 14.4)
Max Power Output: 300 W (45 W x 4 & 120 W x 1) specs at 12.0 Volts
Continuous Average Power Output: 240 W (35 W x 4 & 100 W x 1 into 4 ohms 20Hz-20kHz @ 0.04% THD)
Typical 2-ohm Stereo: 45 W x 4 @ 0.4% THD
Typical Bridged Power: 90 W x 2 &100 W x 1 @ 0.4% THD
Bass Extender Control 0-12dB
Selectable 4-Channel High Pass & 1 Channel Low Pass, 80, 120, & 180Hz
Bridgeable 5, 4, or 3 Channel Operation
Pulse-Width Regulated MOSFET Power Supply
Speaker Level Inputs
Double-Sided Glass Epoxy PC Board
65 bucks shipped
I got this in a trade, was told it works flawlessly. It is missing a screw or two for the inputs i believe) You have 1 week to make sure this amp works, if it doesnt, i will refund you for the amp. Remember, you have 1 week to test her out. I have no way to test her ATM...
65 bucks shipped
