circuit breaker?
From alt to battery? Sure most don't recommend it because circuit breakers can fail easier than fuses. Ive never had a problem with circuit breakers, but on my car I would only use a ANL form batt to alt strictly for safety percautions.
knukonceptz.com might have them and if they don't you can get them off of ebay or sounddomain. Look into a stinger I always had good luck with their CB's. Why not just use a ANL fuse?
i just like them better if i need to quick disconnect the main power to the amps if i am working on my system.
So you would rather use distribution block? Is there a fuse in a distribution block?
No not a distribution box a inline ANL fuse
one of these
I don't know what you mean. You can get fused distribution blocks, and the ANL inline fuse holder that I showed you in that picture uses a fuse.
What do you mean?
I thought distribution block had fuses inside of it like circuit braker.......
05fronty
SALT PETER
05fronty
conway,ar
blackgeltabs
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
