TheVille
I recently purchased a Batcap 400 which recommends using a 100A circuit breaker to protect it. I also require a distro block because that will be the easiest solution for me to get them (amp & batcap) wired in parallel. So what I need is a Distroblock with built in circuit breaker function that can accept 0/1 wire. I have found a two on ebay made by visonik and audiopipe but I wanted to find out if I have more options. It would be really nice if I could find one with interchangeable breakers so I could have 100A breaker on batcap and a slightly larger one for the amp.
Also, the batcap is suppose to be able to sustain 400A for 8s, the most I could ever see myself pulling from it in 200A though. Does anyone know if it would be ok to put a larger breaker on the batcap or would the batcap completely discharge before popping the 100A breaker anyways?
Thanks for any information and help.
-Keith
-Keith
