Have finally finished my amp install on my chevy 2500 standard cab now I am just looking to mount the amp behind the drivers seat. Back of the cab is sheet metal with two levels if you know what I mean, space between two levels is about 3inches and the depts of the sunken in level is about half an inch. My plan was to mount the amp on plywood along with crossovers and some other stuffand then epoxy anchors to the back of the cab with 3in bolt sticking out the plywood with amp would then be spaced off the carpet with half inch spacers or so and then secured with clamping knobs. I like this idea, but the question is how do I anchor my bolts in without going through any metal so what surface do I sink bolts into and then epoxy to the back of the cab? I have 1in x 8in metal strips but I dont know how secure that will be when epoxied to the cab.
Any suggestions would be greatly appreciated, thanks
