Cheap quality install accessories
wew lad
wew lad inc
Picked up this big box full of install accessories from back in the day, pretty sure it sat there for years, it's all unused besides a few things taken out of their packaging.
Distro blocks:
Stinger gold/Raptor/Tsunami GFDB4 (different brand, same item) 3x4ga input, 4x8 ga out distribution block uses glass AGU fuses 11 @ $8ea
Stinger pro 3x4ga input, 3x8 ga out distribution block uses glass fuses 1 @ $6
Tsunami FDB804-MANL distribution block 3x4ga in, 4x8ga out uses mini anl 2 @ $8ea
Battery terminals:
Tsunami BT 805/Raptor pair of battery terminals 1x4ga and 2x8ga outputs compression input. clamp style, 24k hard gold plated 5 pairs @ $10 ea pair
Raptor clamp style 24k gold plated 1xdirect 8ga, 1x direct 4ga, and one ring terminal bolt output 5 @ $6 ea, pair for $10
Premium install components:
tons of distros with integrated voltmeters, even one with a relay. Decided to grab one for myself and use it because they're so nice. Oh yeah, they're also cheap. $12/$15 ea.
Raptor integrated voltmeter distribution block 3x4ga in, 4x8ga out uses AGU glass fuses. has integrated indicators to tell you if an input fuse is blown, see post #4 6 @ $12 ea
Raptor integrated voltmeter distribution block 2x1/0 in, 2x4ga 2x8ga out ANL fuses 5 @ 15ea
Tsunami integrated relay distribution block 1x1/0 2x4ga in, 2x4 ga 2x8ga out ANL fuses 1 @ 18
-has LEDs for each output showing if they're active and can be used to cut off power draw when your system is off - 2nd pic
Buy the whole box (42pcs) for $120 shipped!
deals on multiple items
shipping is on a per order basis, generally it will be less than $5. ill make deals on shipping for purchases of multiple items, PM me for a quote
pics in the description, full album is here:
Imgur: The most awesome images on the Internet
Do you have any pics of "Raptor integrated voltmeter distribution block 3x4ga in, 4x8ga out uses AGU fuses6 @ $12 ea" ?
Thanks.
im glad you asked about this, because i didn't realize how different they were, i assumed they were like the 1/0 input blocks but they're not. they have completely different LED screens with a display showing if a fuse is blown or active as far as i can tell, should of asked more for em but im not gonna up the prices lol ill power one of them up when i get time but here's a few pics. this one had a somewhat broken glass lid so it'll be discounted another few dollars - pretty cool distros
I like this. And one with a relay? So.you have a block that takes 0 gauge and have volt meter along with this distro? Any like the one pictured that takes anl fuses?
Hit me.up later
I like this. And one with a relay? So.you have a block that takes 0 gauge and have volt meter along with this distro? Any like the one pictured that takes anl fuses?Hit me.up later
the distro on the bottom is the 2x1/0 in 2x4ga 2x8ga out with voltmeter
only one block with the relay
wew lad
wew lad inc
wew lad
VA
wew lad
