Cheap amplifier options and what would you chose
alex16
I am not looking for a professional setup/sound, I just want to take my car stereo to the next level above the HU power. (If I feel the need to upgrade this amplifier will be passed onto one of my other vehicles for sure).
I want the amplifier to power my JBL GTO608C 6.5 components rated at 70w rms @ 2ohms. I want to have rear jbl 6x9's but have been told they are not needed with proper amplified 6.5 front components in my 1999 civic coupe. In the future I'd possibly use this in my 1995 F150 crew cab (6.5 front/6x8 rear) or my 1999 Ford windstar (6x8 front/rear) so a 4 channel will be better.
I found the following...
MTX Thunder 5400X $60 locally
5 channel
50 Watts x 4 into a 2 Ohm 100 Watts X1 RMS into 4 Ohm
Sony Xplod Xm-Gtx6040 $60 locally
2 ohms: 70 watts x 4 chan.RMS
Sony XM-554zr $52 shipped used from amazon
2 ohms: 65 watts x 4 chan RMS
Sound Storm Laboratories EV4.400 $27 shipped used from amazon
RMS power 4 ohm 50W X 4
Boss CX350 $37 shipped from amazon new
RMS Power @ 4 ohms 50 watts x 4 channels
Alpine Mrp-T306 Flex 2 $? up for trade on CL (I'd like to trade one of my old crap head units)
2x50W into 2 ohms
I found this as well ... I could then use my boss ava-550 100 Watt x2 RMS @ 4 Ohm for my mids and this for my 10'' mtx 5500
Kenwood 8105D $40 locally
300 watts RMS x 1 at 4 ohm
(same situation for this mono amp)
alpine V-power MRP-M450 $50 locally
220 watts RMS x 1 at 4 ohm
some kind of kenwood... cant make out the model number $50 locally KENWOOD 500 WATT AMP
The bottom of the list... I really don't want to wait and save, but it is jbl...
JBL MA6004 Marine $84 shipped used $92 shipped new
Looking for either a 2 channel or a 4 channel, a 2 channel for the current vehicle but I'll take a 4 channel to use until I find a good replacement, it would then be passed onto another vehicle.
Also from my wanted post....
autotek 75.2 $60 shipped
100W RMS x 2-Ch @ 2-Ohms
MTX thunder series w/matching electronic crossover $60
60X2 RMS
Precision Power i350.2 $??
RMS Power @ 2 ohms: 175W x 2
I am using an Alpine KTP-445U ( a very compact 45wX4 @4ohm or 80wX2 @2ohm) amp to run my front channel and it was a major improvement over my head, which is an Alpine CDE-147BT. The little amp is powering a set of Alpine components in the doors and a set of Alpine 4" speakers in the dash. As small as it is, it is 2006 CEA certified to be making 45w x 4 @ 4ohms. It has a crossover and can be hooked to rca jacks or line level speaker wires. I have seen them at around 60 on ebay, brand new they are 100 bucks. It would be all you need for that component set, and would power those 6x9s should you decide to add them later. Also, it is super easy to install.
The 5400x by far.
---------- Post added at 08:58 AM ---------- Previous post was at 08:57 AM ----------
What's the condition of the 5400x? If you don't want it, get it for me.
60X2 RMS
5 channel
2x50W into 2 ohms
seriously if you need lots of power on the cheap
Precision Power i520.4 (i5204) 520W 4-Channel iON Series Class D
if you can the black ice 520 is only 5 dollars more and its active capable
this will absolutely DESTROY every suggestion you have brought up so far OP. Dont be in that mind set where you keep buying junk and junk and more junk and some garbage on top of that. Save up man amps are important components in your system. its not that much more money but the performance difference gap between your garbage amps and these legit amps is astronomical.
alex16
alex16
Minersville, Pa
alex16
