mono is a sub amp, 2 channel is for 2 speakers, 4channel is for 4 speakers multi channel is usually 5 or 6 channels for 5 or 6 speakers. Bridgable means that you can make 2 channels into 1 more powerful channel
if you have 2 subs, we need to know what the power rating is on them. if it has a low rms rating, then you could use a 2 channel amp and run one sub off off each channel of the amp. if you use a mono channel amp (mono=1) then you could run one amp for each sub.
more accurately a channel is a distinct signal. eg, front-left, front-right, ect... a 4 channel amp could be used for stereo sound with front-rear fade. or it might be used for front-only stereo sound with a bridged channel for subwoofer use. in the future, it might be used for 4 channels (of the 6) of a 5.1 audio system. advanced users might find other uses for extra channels other then different speaker locations. eg, they might run tweeters off of 1 channel and midranges off of another channel.*
i mention this because for subwoofers, it is common to hook multiple subwoofers to a single amplifier channel.
*if you don't know why you would do this, then don't. i list it only as an example of something that advanced users might do. this is "biamping" and requires extra steps beyond simply plugging the speakers into an amp.
My subs are 1100 peak and 400 rms but im planning to get some better subs cause they are dual's can i use a mono amp for them and if i plan to get better subs?
