Changing my mind about hifonics?
chris96camaro
Foreign and Domestic
I was interested in getting a hifonics brutus bx1500d to run my two JL 12w6v2's. But i keep reading about all the problems people are having with their hifonics amps. What would be some other good amps to run my subs?They are 4 ohms subs and would wired into a 2ohm load...their specs are as follows...
Nominal Diameter: 12 inches (300 mm)
Continuous Power Handling: 400 Watts
Voice Coil: 2.75" diameter, 4-layer, Kapton former
Available Configurations: Dual 4 ohm only
Xmax (one-way, linear): 0.65" (16.5 mm)
Sealed Enclosure Range: 0.90-1.50 cu.ft. (25.0-42.0 liters)
Ported Enclosure Range: 1.25-1.75 cu.ft. (35.4-49.5 liters)
VRC™ Technology: YES
W-Cone™ Technology: YES
Elevated Frame Technology: YES
Floating Cone Attach Technology: YES
NeckVent™ Technology: YES
Depends on your budget.
But, with the great SQ of the w6v2, I wouldn't suggest using a Hifonics on them //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
How about the new KENWOOD KAC-9152D, it is rated at 900 watts rms @2ohms and 1ohm. I have a kenwood now and have never had any problems with it. Anybody know anything about their new line of amps? Are they rated close to their actual power?
I have an AudioBahn A2502DP Digital Series that will give each sub of yours 500w @ 2ohms. THe amp is brand new in box and ill let it go for $225. Check your PM for contact info.
*sigh*, the ol' tides are a'turnin on the forum bandwagon //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Go with RE //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
chris96camaro
chris96camaro
Charlotte, NC
italianlifter17
