Central Region Centerville and Bryan Ohio Events
IA,IL,IN,KS,MI,MO,MN,NE,OH,OK,TX,WI
I'll be there and im pretty sure i'll be competing...but does anyone local do work on amps?
..The xxx10k apparently had it's screws vibrated loose on the rca/audio audjustment end of the amp and I was getting some fairly nasty sounds from the btl, so I looked through my setup for the cause and reattached the 2 screws that I found and the situation is much better but I found that in the time that it was all unscrewed, the power light must have gotten loose and is no more (need to pull the amp and open it up...the light is probably right inside), so I kind of was wondering if anyone could give me a hand with it, might also have some small issues with the insides of the rca inputs...
Still works n all, but definitely isnt 100% //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
just orderd the 15" soundstream splx's ... im rebuilding a wall box that i had for 2 18's and makeing if for the 15's ( i know, a wall for 2 15's is kinda gay, but i always wanted to see what it can do) .... that box is probably going to be temperary until i get more wood to build a nice 9 cube aero port box tuned looooooow. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif so ill see you guys at the comp then in centerville. maybe byran
cf2004
cf2004
Lima, OH
audioarsonal
