Sold ***CDT SQA-4100 4-Channel Amplifier***
basebalz13
D-money
Most of yall probably dont know about this amp so heres a little description
The CDT SQA amplifier line adheres to the most stringent engineering principles to bring you an unparalleled listening experience in the automotive environment. We offer a high end 4-channel amplifier with guaranteed specifications and a detailed power specification of each model. Typical power values are approximately much higher than rated, a specific individual birthsheet is supplied with each amplifier.
The SQA-4100 Class AB amplifier features: internal variable 24db per octave high and low pass adjustable crossovers, built-in subsonic filter, 5 way protection, 2 Ohm stable circuits, soft start/mute circuit, trimode output configuration, daisy chain through output RCA, input level controls. The amplifier utilizes massive robust power supplies and amplification stages for the maximum installed flexibility and reliable performance
Power Output DC 14.4V
RMS at 4 Ohm- 110W x 4Ch
RMS at 2 Ohm- 150W x 4Ch
RMS at 4 Ohm- 300W x 2Ch
SN Ratio- >100db
THD (HF-A)- 0.03 %
Channel Separations- >55db
Input Sensitivity- 0.15V-5V
Input Inpedence- 47 Kohm
Slew Rate- 10V / µsec
Damping Factor- 200 at 4 Ohm
Fuse Rating- 40A x 2 EA
Price is 399 shipped each ( 2 total) with 1 year warranty BNIB!!!! it is CEA certified!
Hey dude, you aren't on AIM so I'll tell you here. I just sent Scott at HAT an email asking him some questions about running active so once him and I talk and I figure things out, then I could be more interested in the amp. I still am interested right now with it just gotta figure some things out bud.
alright sounds good, ill talk to dave more about how itll do with runnin active with your setup and let you know too
basebalz13
D-money
basebalz13
roanoke, virginia
basebalz13
vegang
vegang
