CDT Mid Woofers
wanderer1
Item(s) for Sale: 4 CDT EU-6, 2 CL-6M, These are 2 ohm models
Item(s) Description/Condition:CL-6M, from woofersetc.com they have them for $159- CDT Audio Component drivers with "Contoured Dispersion" provide the ultimate solution to the sonically intense reverberant field car audio environment. Most factory speakers are located in the same place, and most of our competitors take the "shotgun" approach with multiplicity of disparate sound sources. Our integrated oblique driver system provides a single mounted contoured dispersion door mounted system, which produces a sonic image that virtually appears "right in front" of you. It offers maximum sound definition with a minimum of drivers. This means it's also very easy to install. Simplicity at its best. They're competition quality and they literally contour the dispersion so it immerses you in sound. What you hear is an astonishing dimensionality. Critical ears have turned to CDT Audio and you'll be a believer too.
Technical Specifications: •Cone: Coated Carbon Reinforced Paper
•Diameter: 6.5" (170mm)
•Sensitivity: 81.65 dB
•Power Handling: 70W RMS (100W Peak)
•Frequency Response: 40 - 1000 Hz
•Nominal Impedance: 2 Ohms
•Voice Coil Diameter: 1.0" (26mm)
•Peak Xmax: 5mm
•Magnet Weight: 20 oz
•Mounting Depth: 2.63" (66.8mm)
•Cutout Diameter: 5.78" (147mm)
•Outer Diameter: 6.63" (168mm)
EU-6 from the CDT site-Introducing CDT Audio Euro norm series. CDT sees a strong trend in cars getting smaller and smaller. To address these smaller cars which sometimes have very slim doors, CDT have com out with a less depth yet very power full smooth audiophile sound quality European specification norm speaker line. The exciting new models not only slim but due to new European manufacturing techniques and efficiencies are available, and CDT engineers closely following the EU-standard for speaker design. we have a speaker line that fit almost any installation challenge at a very affordable price. Yet, typical of CDT Audio, the quality has not been compromised at all.EU 6
EU norm 6.5” cast mid woofer
Technical specs and contents:
1 pr EU 6 6.5” cast mid-woofer
Power handling: 170 watt RMS @ HPF 120Hz.
Frequency response: 65Hz-20.000Hz.
Impedance: 2 Ohm
Sensitivity: 91.6 dB
Mounting depth: 2.74”
All brand new
Price: $95 a pair shipped in conus
Shipping and Miscellaneous Item Information:I pay shipping buyer pays any other fees
Item Pictures: CL-6M EU-6
wanderer1
wanderer1
Laughlin
wanderer1
