CDT ES60CV Gold 6.7 components with ex550 I crossovers
drt27
1 set CDT ES60CV Gold 6.7 components with upgraded ex550I crossovers
Excellent condition Mechanically 10/10, Cosmetically 9/10. May have some butyl rubber gasket material still stuck to back mounting. I had these sandwiched between mdf and butyl rubber gasket material. They were powered by rear channels of a PP900.4 as rear fill.
Sounded excellent, still in perfect working condition. Remove system to get a bigger vehicle.
$160 shipped
$150 Picked up if you are local to zip 27317
Will ship with tracking number provided within 24 hours of receiving payment thru paypal
also have other ads for cdt front stage & singer alternator for dodge hemi 5.7 if anyone wants to drive to pick up items I will give away mlv/acoustic foam barriers for doors,back walls and roadkill pads for floor of reg cab dodge ram 1500
pretty sure they are 4 ohm
I know the whole set subs/mids/tweets was 4 ohm after crossoverMX-2
Technical specs and contents •1 pr 2” hybrid mid/tweeter drivers
•Black injection molded frame
•Diameter: 2” (52mm)
•Frequency response: 200Hz-20.000Hz
•Sensitivity: 86.dB
•Power handling w/xover: 90W-140Watts HP
•Magnet: Neodymium
•Voice coil: 1.0” (25mm)
•Surround: Rubber
•Frame: Injection molded
•Frame OD 2.65” (67.5mm)
•Mounting depth:1.26” (32mm)
•Cone: Fabric/paper carbon reinforced
•Impedance: 4 Ohms
will set both sets of cdt sets I have listed for $200 to someone in N.C.
pick up only!!
will not ship for this price, both sets in excellent shape just no longer need.
drt27
drt27
randleman, n.c.
drt27
